hi. we have purchased VRAy for Rhino in october 2007.
after few problems in windows, suddenly we can’t assign Vray
as render plugin in Rhino and we are moved on a window with a very long Activation Code where we should write a Responde code…we have only original serial but nothing else, where’s the problem?? please let us know something as soon as possible, we have to use VRay for an urgetn work.
Re: Activation - Response Code on Rhino4 with VRay purchased
Hello-
We are sorry you are having problems. Please try the following instructions.
1. If you have not already, please register at http://www.asgvis.com for a user account. You will need to confirm this registration via email so be sure that your email address is correct.
2. Login to http://www.asgvis.com and click on “My Files” under the User Menu section on the left side of the screen.
3. Click on the V-Ray for Rhino category.
4. Find the file named “V-Ray for Rhino v1.00” or “V-Ray for Rhino v1.00 EDU”. This a new installer for the product.
5. Download the installer. Once it is finished downloading, uninstall any previous version of V-Ray for Rhino that you installed previously.
6. Install V-Ray for Rhino again with this new installer.
7. Register V-Ray for Rhino using the same serial number you received when you purchased the product.
Corey Rubadue
