.ADAGIO.
.ADAGIO.
Website:
Instagram:
Facebook:
I created a classical apartment to contrast the modern simplicity and colorful fabrics under some low lighting situation.
Dark & Moody are two words that describes this space flawlessly. Its something I wanted to do in my free time since I started working as 3D artist but I was never on the mood or had the time
and if you are already working on that field then you probably know that inspiration is just not there sometimes.
The sofa by BOSC, the armchairs and the low table by BuzziSpace makes you feel that warmth and relaxation feeling alongside the danish design idea.
On the other side the moldings and the gold bar trolley gives you the idea of a minimalistic art deco style which happens to be one of my favorites.
In this project I used 3ds max, Corona renderer, Photoshop and After Effects.
Hope you enjoy!
C&C are more then welcome.
Great work, well balanced light and compositions!
Thanks a lot!
Really like your renders.
But why After Effects? What AE can do what Photoshop cannot do?
AE has better handling of 32 bit images than Photoshop, is my guess as to the reason why.
Thanks!
The only reason I use AE except there is an animation, is the Depth of field with a Zdepth mask
And the reason you don’t render true DOF, is because render times or flexibility of post?
Both i’d say, especially because I work that kind of projects not from our office but from my home pc which is threadripper 1950x OC so i do not want deadly render times and I change my mind every hour about f/stops :tongue:
true DOF is fun though, you can play with blades etc. like the one below. Trying to make you feel dizzy
