Adam's Residence
Here, is a house that I am working on. I am not sure about the colors, but that’s what the builder wanted. I asked for the color board and she gave me two colors, one for the windows and one for everything else.
nice! good sense of scale and space. only thing that bugs me particularly (and its a small thing) is the leaves on the tree, foreground right, and also the grass.. very unnatural colour. too much blue.
I tired using a preset from Forest Back. The forefront tree is there to block some empty space. I think this one will go through some iterations, so I’ll address those things.
The greens are so cold…Can you warm it all up? Desaturate it a bit?
I also changed the over all color, which was supposed to me more cream.
its looking better. That fg plant is killing me though.
Also the brick could use a bit more depth, feels flat a bit. Same with that fence.
I usually use Walls & Tiles, but it’s broken and crashes. So, I had to go old school.
The tree in front of the house bothers me… it’s braking the view of the house in two… distracting.
yes. I moved it as far off center as I could.
Lost some things, but here is an update.
As above the greens need some work. It takes a minute to do in photoshop… I did a quick tweak. Hope you dont mind.
Agreed, this is much better. Still a bit of cyan in there for my taste, but a huge improvement.
Checked it on another screen and yah, the greens feel quite ‘sensitive’ in this image for some reason…
James’ version is a huge improvement. Greens of the original were just hurting my eyes.
Here, is an update. Hopefully, the greens are not hurting anyone.
I just went to the doctor, he told me it was fine. Update is better although I would dial down the blues just a little more in the greens of the grass and that tree in the back on the left. Then it’s perfect.
I am glad your doctor gave you the okay :)[quote=“Vizioen, username:Vizioen”]
[/quote]
Much improved! I would still dial the blues down just a hair more. :slight_smile:
Okay, I removed some blue from the grass and that left tree. also, here is the night version.
This might be personal taste, but I’m also thinking that maybe your monitors are a little off? Because the grass and the tree are still blueish :confused:
