The option speeds up rendering with HDRI a lot, is some test cuts the render time in half.
But it doesn’t work with light select, which for animation is not ideal, as there is lot of compositing with light select passes.
I split it to direct and indirect, direct is clean, but indirect has a lot of fireflies all over the image.
Just saying as exp on this, since it is WIP still.
cheers
