Add ability to Include/Exclude objects from Corona Camera Clipping
Status: pending
Good afternoon Corona Team
I wish you could make it possible to exclude objects in the camera clipping. For example, I want the wall to be cut, but I don’t want the flower in the pot to be cut either. But there is no option to do that( and You have to completely remove the object from the camera’s view.
Thank you for your attention
Submitted on AHA Ideas by Владимир Власов (CMAX-I-176).
Instead of using the camera to clip objects, you can use the Corona Slicer Material to cut through objects in your scene. If you also use the Corona Ray Switcher Material with the slicer, it will make sure your lighting stays the same, even after slicing the objects.
To do this:
  1. Apply the Corona Ray Switcher Material to the slicer object in your scene (the object that will cut through other objects).
  2. In the Corona Ray Switcher Material, plug the Corona Slicer Material into the Direct override slot.
  3. This setup will slice objects in your scene without affecting the lighting in your scene.
This way, you can slice objects without changing how the lighting works in your scene.
Submitted on AHA Ideas by Arpit Pandey.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
