Add AO slider for contact shadow control
Any plans to include an Ambient Occlusion slider in future builds? It would be great to be able to control the amount of AO especially for contact shadows? Unreal has the option, vray also has that option.
Enscape tries to imitate real world lighting. Ambient occlusion is an artistic effect that imitates multi bounce lighting caused by sky illumination. We use a certain type of ambient occlusion for very near distance details that are lost in our process of filtering the image noise. Simply scaling the influence of that would not look very nice and will lead to flickering in videos. But maybe we’ll offer something similar in the future, thank you for your request.
Ambient occlusion happens in everyday lighting. Not just an artistic effect. Some people use it as one, but look at the corners where walls meet, objects touching the ground, you’ll see it happen.
@vjaramillo_cg Have you tried to use the ambient brightness slider? In most cases this slider is sufficient.
Ambient occlusion describes a technique to fake multi bounce lighting on close surfaces. It is not a phenomenon that you will find in a physics book, it has nothing to do with real world lighting behavior. It’s a hack to workaround missing light transport. It can be used as an artistic influence though.
One assumption (that’s usually wrong) behind AO is that all surfaces absorb each others light. This is especially wrong if you deal with bright surfaces (even bright via indirect lighting), then nearby surfaces can become brighter - not darker. → It’s a hack to mimic what you sometimes observe, but not what light actually does.
The term and technique is a way of imitating lack of light in tight corners where light can’t reach, but it does happen in real life. Agree to disagree. Properly used increases detail and contact vs having object seem like they are floating.
An AO slider could be used as an artistic tool like the outline slider. A tool to change the graphic look without the goal to be 100% photo realistic only.
Enscape is not capable of producing photorealistic detailed shadows for small details such as reveals. AO controls ( or a separate AO pass ) would help us overcome this when attempting to create high quality still images.
Hey @renderwiz , @Micha and @vjaramillo_cg , your voices are being heard and I’ve filed a request to implement AO accordingly, for either artistic purposes, or other use case scenarios mentioned by @renderwiz and @vjaramillo_cg .
Very coo. Thx.
Absolutely agree with @vjaramillo_cg - Any updates on this for 2020?
+1 from me too.
At least at the moment there are no news I can share regarding this subject. Gladly up-voted the topic through your behalf though @povoom_1 .
This is a known shortcoming and we are working on that. Fixing or workarounding these issues be implementing an AO slider would be the wrong direction.
+1 - Arch Viz artists are cheating reality every day to make the image do what we want. I use the Outline feature on just about every Enscape image simply because I want those edges to have some shadowing. Architects and designers love it. So I definitely would love to see AO in Enscape as well.
I agree with the arguments of Thomas Willberger and VStudio. However, I also like to use AO (in other renderers) for example to over-emphasize plasticity where required and since it is a cool graphical feature I don’t care if it’s fake or real, as long as the result is good :wink:
+1
