Like the tittle says, a way to add the camera override environment with Lightmix setup
Submitted on AHA Ideas (CMAX-I-100).
Status: declined
Isn’t this the same as https://chaoscorona.ideas.aha.io/ideas/CMAX-I-94 ? Can you explain how LightMix would be involved in this as I don’t see the connection? Thanks!
Submitted on AHA Ideas.
I think that you could delete this idea, maybe I didnt configure correctly my scene, because now its working, What I was asking was that environment from camera could be integrated in the Lightmix environment layer.
The thing was that in a prior project, everytime that I wanted to use Lightmix Setup, 3ds Max crashes and I needed to do it manually, and when I setup environment nothing appeared, but like I said, its working fine, thanks.
The other idea was something very different, Its like having a Lister/Lightmix per camera, which, is a really good thing to have. I use State Sets for this purpose.
TY for the extra info! I’ll close out this idea ![]()
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
