Add Light Grouping Functionality in the VRAY Light Mix List inside of VFB
Status: pending
Add the ability to combine light selects into folders. This will improve the management of the lights inside VFB.
It would be nice to have a folder similar to the one for the color adjustment layers. This way different recalculated groups of lights could be controlled together with other light selects. We could hide and show all of them at once from the folder. And we could rename the folder as well.
Submitted on AHA Ideas by zhushitong zhushitong (VRAYMAX-I-73).
Hi, this is possible even now. You can set different criteria for how the lights are considered in LightMix. You can find this in the VRayLightMix render element settings.
Let me know if this helps, or maybe you meant something else.
Submitted on AHA Ideas.
Suggestion: Add Light Grouping Functionality in the VRAY Light Mix List
Currently, the Light Mix list in VRAY displays individual lights clearly. However, when working with a large number of different types of lights, managing them can become challenging. To address this, I suggest adding a “Light Grouping” feature, similar to what is available in Keyshot, where users can intuitively organize lights into groups. This would allow lights to be grouped based on scene or object requirements, making it easier to adjust and control the lighting effects of each group.
Benefits of the Feature:
  1. Improved Workflow Efficiency: Users can quickly locate and manage relevant light groups without needing to search through a long and complex light list.
  2. Simplified Scene Debugging: In large scenes, users can easily hide or adjust specific light groups with a single action, streamlining the lighting and testing process.
  3. Enhanced Flexibility: Different types of lights (e.g., environment, spotlights, area lights, etc.) can be categorized based on project needs, allowing for easier fine-tuning and optimization at various stages of rendering.
  4. Familiar and Intuitive: Similar to Keyshot’s intuitive light grouping system, this feature would allow VRAY users to organize lights in a more visual and user-friendly way, improving overall scene management.
Submitted on AHA Ideas by zhushitong zhushitong.
Hi so basically you want to see the list of lights when you expand a group? What you are missing now is the ability to expand a group and to control the lights individually inside, correct?
YES
Hi, this is not possible. Once the lights are combined (depending on your choice for grouping in LightMix render element settings ), they cannot be separated and controlled separately in the VFB. This is specified before rendering, and they are calculated together in LightMix, which explains why they cannot be shown independently under a folder. We could think of adding a folder option in LightMix. But this option will not split the already formed light selects that contain more lights in them.
Thank you for your response! I understand that once lights are combined in LightMix, they cannot be separated in the VFB. However, I think adding the folder option in LightMix would still be very helpful for better organizing and managing different types of lights during the rendering process. Even if the grouped lights cannot be split afterward, having the ability to categorize and place lights into folders before rendering would enhance the workflow and make light adjustments more intuitive. I would greatly appreciate it if you could consider this feature in future updates.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
