Add node buttons in node editor
Adding a list of buttons for each node in the node editor would be a huge UI and workflow improvement instead of having to go through submenus each time you just want to add a node.
This could be just for Corona nodes, but also great if you could add them for C4D nodes as well.
Hi there, I’m not sure I fully understand your request. Can you do some kind of mockup at all?
Sure, basically like Octane has it it in theirs.
+1
Octane provides also a search menu that filters the nodes, and its color system helps to keep things organized
Useful idea.
Hi, noted internally.
(Internal ID=815655677)
