Add only Toon line
Can I add Toon Line while maintaining the material color of each object? (One Pass)
Overlay only the Toon line like 3dsMax?
In material override, the color of the object is lost.
Hello, Yuji,
Thank you for this question!
For each scene material, you would need to create a corresponding Toon material, slot the original one as base and then apply the Toon to objects which previously had the base material applied. Depending on your project, this may be very time-consuming. Unfortunately, there is no easy workaround.
There is a number of improvements to the Toon functionality that the developers would like to implement in a future update. Adding Toon render element is one of them, however, at this time I cannot share any details.
Kind regards,
Peter
expect it for Improve!
Thank you
