Add server... from file
Hi All!!
Really simple request (I hope)!
Why don’t you add an “import IP list from file…” in the V-Ray distributed rendering settings page?
This would be useful just once per year (every new 3dsmax realease I mean) but since we have several machines to configure and several PCs in the renderfarm could be easier to import the list of render slaves from a txt file saved in a specific location.
That’s it :slight_smile:
Thanks!
The server list is in a text file called vray_dr.cfg stored in the plugcfg folder for 3ds Max - usually something like “c:\users\username\AppData\Local\Autodesk\3dsMax\2020 - 64bit\ENU\en-US\plugcfg” - you can just copy over the file from the previous 3ds Max release.
