Hi Morne, thank you for the reply.
I’ve been doing that but in the compact mode… there you can also search by name.
But if you start typing map #… only a handfull of maps are shown. Even if you just start typing “ma”, I get some maps with their n° but not nearly a fraction from what’s in my scene.
There’s a question though; if the map is part of a complex shader including many textures and materials, which material should I print? I mean, if you have a sub-object material with a blend material with a VRayMtl with a Mix texture for bump and one of the sub-textures is a Normal Map - what do I print in that case?
Top node would be best I guess for finding it. If it’s no hassle to implement you could write the actual node in paranthesis after the top node, but I think it’s not high prio.
