Users often work with Enscape paused when working on large Revit models to avoid the constant loading to Enscape delays. It would be helpful if there were a simple “Update” button in addition to just toggling live updates back on, just to have to pause it again right away.
Submitted on AHA Ideas (ENSCAPE-I-1462).
When working with even vaguely detailed or large models, Live Update can take a while to finish exporting to Enscape… and I to wait for it to complete before i can turn Live Update back off, so therefore I often forget to – and then when I go back and make a tiny change in Revit I realize “oh crap i forgot to turn off Live Update and now i have to sit and wait for it to finish”.
Submitted on AHA Ideas by Brian Fitzsimmons.
Merged with another idea for the same topic to keep the Portal tidy.
Submitted on AHA Ideas.
Please add a button where the model gets updated just once and not this fake “live” stuff. Its not actually “live” because the model has to export every time I make a move. It is only live when it comes to materials, where the changes are instantaneous. It is annyoing to move something 1" and waiting for the model to export. I always forget to turn off the play button and Im and up waiting for the export to take place. It is annoying especially with bigger models. I’d like to be able to click a button that updates the Enscape model once and then it doesnt remain on. If the updates were truly “Live” it wouldnt need to export with every tiny change. It takes forver to wait for the export function (when I say forever I mean 20 to 30 seconds which is enough time to get annoyed)
Thank you.
Submitted on AHA Ideas by Sebastian Toro.
Can you share a little more on the issue?
Is the one click more really that bad? Or is the waiting time the bigger issue when updating?
The one click more is really that bad, because it can’t be clicked immediately after the first one.
Once Live Update is turned back on, the system doesn’t accept any new inputs until the update is complete, which in the case of a moderately complex model may be a matter of 10 seconds or sometimes quite a lot more. In that time I’ve navigated away to check emails, got up to do something away from my desk, or something else that moves my focus away from telling myself “okay, remember you have to turn this back off as soon as Enscape allows me to register another input in Revit – just please sit here patiently before moving on to something else”.
Therefore, more often than not, I end up forgetting to turn it off again – and I learn this when I make some miniscule change again and I have to wait for Enscape to update all over again a second time… it is then that I am frustrated enough that I sit there and wait for it to be done and then turn off Live Update.
A single-click, manual one-time-update button would be much more useful and save everyone a lot of time and frustration.
Thanks!
Agreed with above. When you are actively exploring design solutions going back and forth between enscape and Revit/Sketchup etc. you generally don’t want Enscape to live update. You want to make ALL the changes (which may involved 3 or 20 operations) and then hit one button for enscape to update with those changes. The “live update” is only useful if it does not interrupt your modeling workflow. Because it interrupts your modeling workflow with every change, you have to turn it off while making changes, or wait 10 seconds between each of those 20 operations. I think live update is great conceptually, but only if there is zero lag in the update (which is probably not feasible). That said, another way to approach this would be to have an update timer that you could set to run the update every 10 minutes - similar to how Revit has timed sync reminders set up. Thanks,
Submitted on AHA Ideas by Adam Martin.
Merged with another idea to keep the Portal tidy.
+1 would definitely prefer an update button over having to toggle the live update on/off. Not sure what it’s like for everyone else but I’d estimate we only want to use the live update about 10% of the time.
Submitted on AHA Ideas by Grey Block.
Agree with the above. I work on very large projects where once I turn on live updates it can take a solid 60 seconds + for enscape to actually update, and there are so many times where I forget to turn it back off after.
At the same time, speeding up how long updates takes would be great. There are times when I change 1 little thing, and it still takes just as long to update as when I move lots of geometry. Maybe if the update was smarter and rather than updating everything every time, it checks to see if something actually changed before pushing the update? I don’t know anything about coding, maybe thats already how it works.
Submitted on AHA Ideas by Jacob Levy.
Having to continuously return to the Enscape tab in Revit to resume and pause updates is a bit cumbersome and disruptive to workflow. Would it be possible to add a control button to the Enscape render window task bar? Thank you.
We merged this Idea with a similar one to keep the Portal tidy.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
