Adding background workflow?
Hi guys, What would you recommend me to add a background image to see through Windows for example? Doing It on enscape? Or better try with postproduction?
Thanks a lot
I have done in two ways.
Method A
Modeled some volumes around my project
Added context pictures from street view on the volumes
This works ok, but shadows from the values can give some problems, but fine for many different shots
Method B
Setup desired views
Export views with material Id and depth
Insert the rendered image as linkes object into PS
Insert the depth or material id as linked objects to
Select the windows areas and use this as a mask on the render image
Insert the background image
Looks fine, but a lot of work, but working with linked objects makes it much faster
Jorgensen
Thanks a lot!
Or try out our horizon presets in the Atmosphere tab of the Enscape settings or insert your own skybox.
