From forum discussions it seems matte shadows are not denoised during RT is because of performance issues when denoising render elements. It would be nice to have a tick box option though if we are only using a denoiser on its own and no other render elements. As it stands, the rendered object gets denoised, but we have very grainy shadows, which for look dev, and for sharing any test renders can be jarring.
Submitted on AHA Ideas (VRAYMAX-I-97).
Hi, can you share the forum discussion as a link here? Is it related to a new behavior in V-Ray GPU?
Submitted on AHA Ideas.
It probably does affect GPU, but I only use CPU rendering. I also use Maya, but that ideas section doesnt seem to be in use.
Here is the forum thread.
https://forums.chaos.com/forum/v-ray-for-3ds-max-forums/v-ray-for-3ds-max-problems/1140953-vray-matte-shadow-makes-noisy-alpha/page2
Hi, we checked, and the denoising behavior differs between Maya and Max. We will register it in our system, but an idea would not be needed. Thank you.
Hi, from what I saw we proposed a solution in the forum. Does it work for you?
AHA Ideas status: New.
Set during AHA Ideas to Discourse migration.
