I’m looking for a solution to 3ds max that works like when you want to resize the Canvas Size in photoshop. Basically adding X amount of pixels to only the top of my image.
If I change the height in render output I will also get “extra” ground that I have to render.
I made a script that did that a long time ago, but that was some max versions ago and I don’t know if it still works. I can check when I’m back at work in a week. My clients are always changing their minds, so nowadays I just render the images a bit too big and crop in PS, makes it a lot easier when they ask if you could maybe see more of the building to the right…
Thank you Bormax, it’s not quite what I was looking for, but definitely useful for my workflow as well! Maybe we could suggest this script function was incorporated with the new corona camera. Kind of like you can force dof off on a pr camera basis.
Hi Jens. The problem with the thing you want, is that it’s against the “nature” of a camera. Unlike in a handcrafted perspective the “eyepoint” of a camera will always be in the middle of the picture. Therefore you’ll always get more ground when adding more sky (by changing the height of the picture).
I don’t think you’ll find any other way than “render region” to achieve what you want, but I might be wrong
I perhaps absolutely don’t understand the question properly…but isn’t ‘Camera shift (vertical)’ doing exactly that ?
You change resolution composition to more vertical (just like PS canvas) and then shift the camera up to remove the unnecessary bottom part. Nothing regarding the perspective changes, the net end result is simply added upper part on top of original composition.
The only difference to PS Canvas is the slight order of things, as Canvas lets you shift directly at resize, but 3dMas imitates tilt-shift lens process, results are absolutely identical though.
hmm, I feel slightly silly now. That does indeed seem to do the job. Thanks Juraj, hadn’t thought of utilizing the lenshift and output size like that. Apparently I’m not the only one
Uf, I am glad :- ). I wasn’t sure if I wasn’t misreading some more complex issue.
I think it comes down to knowledge of photography within 3D world, lot of people aren’t aware that for example 50mm focal length exists within smaller one like 35mm, if you crop that image, and end result would be identical perspective ( this would be solution to Iker’s issue for wanting something bit wider, he would change focal length, and then crop the ratio to more horizontal). I am pretty sure overscan plugin which I never used does exactly that just calculates it so you don’t have to do the cropping by eye. Shift on top just allows non-symmetrical crop additionally.
There’s many “professional” photographers who believes that focal length affects perspective, it’s no wonder that such misconceptions are spread even further amongst 3D artists. Not to mention those, for whom terms like focal length sounds like mumbo jumbo :]
Heh very true… I still remember “Medium format shows the space differently, you can better fit architecture within it” ( I mean sure, the depth of field is different, but perspective is just perspective ! ),
If you are talking about digital cameras that we have in Max, then yes focal length can lose it’s purpose with perspective corrections.
But in real life it is different perspective for different focal lengths. The vanishing points change place and that is a distortion i think.
So don’t patronize those “professional photographers” that might know something.
I’m not trying to patronise anybody. I just know that changing focal length alone, won’t give you different perspective, unless you’ll change your distance to the subject too, to keep framing more or less the same. If you think otherwise, then please do experiment - stand in one fixed position, take camera with zoom lens and take two pictures at different focal lengths. If you’ll see any change in perspective, please report it back, as i will be very curious to hear that.
You’re very right about distance coming in play. The only changes are the micro lens distortions in real cameras that in overall doesn’t change much.
But we are dealing with digital cameras and that’s not a problem. So you have a point
I don’t understand this sentence.. what perspective corrections ? Tilt/Shift is the only correction available to 3dsMax physical camera, and it behaves exactly the same way as Tilt/Shift lens in reality, with exception of having no limit. Lens distortions on other hand aren’t connected to perspective and are also simulated in same way.
(I didn’t count vertical correction, as it’s not simulation of optical effect and correctly shift should be used instead)
There is no difference to how the camera works in 3dsMax and real-life in any facet, except for having complete control over every aspect that would otherwise be physically limited by camera and lens construction. (and the option to bypass these limits and disconnect depth of field and motion blur from exposure constraints)
Definitely not, but I won’t go further into off-topic, Romullus explained it very well. Nothing to do with vanishing point. This is common incorrect argument people make on photography forums like DPReview. I’ve read few of such threads, never goes well :- ).
