Hello everyone, is it possible to add people cutouts on post production 360 images? if so, how to do it? thanks
Best way is to use Cubic mapping, as then there are no distortions in the images to be accounted for. But, could still be tricky to determine the correct offset to make the person appear to be at the appropriate distance, could try eyeballing it based on things in the image and see how that works (e.g. matching their location to some feature on the floor texture map at the required distance). I guess you could consider adding a dummy object which will be covered over in post by the pasted person. I don’t know of a “formula” for it to determine it precisely, though.
One of those times when a full 3D person may be a better solution ![]()
You could place those people in an empty scene, render with a 360 projection again, and paste the result on top of your original render.
