Adding VRayCoatReflection RE Changes Main RGB Beauty Pass
The subject says it all…
Adding VRayCoatReflection RE Changes Main RGB Beauty Pass.
I have an object with a VRayCarPaintMtl2 applied.When I enable the VRayCoatReflection render element the main RGB Beauty render changes. I remove the VRayCoatReflection element and it reverts to the previous look.
Is this by design or a bug? It’s annoying and unexpected either way.
Max 2021 VRay 5 build 31158
Hi I tested what you describe and you are correct. Just adding VRayCoatReflection RE changes the RGB channel. I’ve logged the issue in our system under VMAX-11893 for review.
Thanks for checking, Vladimir.
