Adjust Material window
Status: planned
please please make the material window adjustable.
Means, the column where the material name is written, is possible to be enlarged. We often have long material names, where the real difference is written at the end; but the end is not visible, because of this super small column. Should be an easy fix, to make this adjustable like the user needs it.
And furthermore: batch import is great, but why is there no batch export? Working with external people and sharing materials by files (no common server possible) is a mess.
Thanks!
Submitted on AHA Ideas (ENSCAPE-I-1485).
Thanks!
Submitted on AHA Ideas by JÖRG MEUER.
Hello. Can you elaborate more on the use case for a batch export? What are your next steps after the export?
Submitted on AHA Ideas.
This would make fileexchange with e.g. freelancers much more easy. Sometimes it is not possible to work with the same server. So getting the exact same meterials, we have so click on it and export it.
After that, importing a lot of materials is easy with the batch import. But exporting this is a lot work, because this is only possible material by material.
Here a selection of all necessary material and export command for all of them would be great.
AHA Ideas status: Planned.
Set during AHA Ideas to Discourse migration.
