Adjusting HDR elevation in Revit
I am working on interior office rendering. Let’s say the office is 50 meters above the ground.
But when I put in my HDR, it’s leveled to my office. Is there a way to change the elevation of HDR’s in Revit?
No. The image displays an immutable eye level. You’ll need a background image taken from the desired elevation.
Thanks. Sadly I cannot find any HDR that is not eye-level
Ti capisco perfettamente. Nessuno fa HDRI ad altezza maggiore dal suolo
I understand… well I have no choice but I hope enscape will consider something like this in the future.
Another source in case you haven’t checked it out yet is the following for free HDR files: https://free-hdri.com/c/outdoor/urban?page=3
This links directly to some HDR’s you might perhaps be able to utilize here, as a few select are captured from “higher than eye-level” e.g. from an office in a skyscraper.
We of course have our horizon presets, but it is unlikely that we will offer HDR’s from our side, given that there is a lot of content free and paid available online already in that regard. A few more (free) sources can also be found on the bottom of this knowledgebase article here: https://learn.enscape3d.com/blog/knowledgebase/skybox-as-a-background/
Some of our users have also captured their own panoramas before (which can then also be used as a skybox as detailed in the linked article) using their phone or something like a drone with a 360 camera, just so you are aware that this is yet another option.
Update on this. I used Site Context instead.
It’s not that great in interior rendering but sufficient enough
If you are able to share the result, it would be interesting to see it. I am wondering what level of site context you input. I try and use HDRI a lot and rarely find one that works. So I always feel like I start adding some context but it snowballs into creating a world.
Ho sognato quando hai scritto foto di grattacieli, ma l’utente chiedeva HDR da altezza maggiore. Sono gli HDri di Polyeven, li ho provati tutti e sono scadenti.
Vorrei ricordare che, secondo il parere di molti, vi sbagliate a non ascoltare le nostre richieste.
Enscape ha già l’HDR e invece è molto utile, può cambiare la luce del giorno e della notte in un secondo. Bella questa funzione di Enscape.
Ma poi trascurate la qualità, la definizione degli HDR di Enscape ha una risoluzione orribile e molto stirata orizzontalmente.
Perchè non migliorare quello che di buono ha già Enscape. Sono anni che aspetto nuovi vostri Hdri, già anni fa alcune riviste di grafica 3D avevano già criticato il vostro basso livello di definizione. I vostri Skybox sono comodi, ma se avviciniamo la finestra è meglio ruotare l’inquadratura del render.
il mio consiglio: si parla sempre di migliorare il flusso di lavoro. 1 Dobbiamo crearci nuovi asset personalizzati 2 dobbiamo fare Hdri…ma in questo modo non miglioriamo la velocità del flusso di lavoro.
Enscape ha sempre ottime idee, ma poi si ferma e non va più avanti e migliora.
Anche la modifica dei materiali del tuo asset ha introdotto una bella funzione di cambio colore al tuo asset: ad oggi è rimasto tutto in sospeso.
Siamo noi clienti a pagare e sperare in qualcosa di meglio. In questi anni l’abbonamento è aumentato oltre il 30%
Spesso pubblichiaye molti rendering stupendi, fatti però con asset esterni, e solo grandi ville con grandi finestre, ma gli architetti fanno solo ville? Io continuo ad avere luce scarsa già a 4 metri dalla finestra. Enscape vince perchè ha poche impostazioni. Ok. Allora perchè non riusciamo a fare ottimi render con apprtamenti normali. Sarà il caso di capire meglio come utilizzare le luci in Revit con Enscape forse non conosco bene ancora come migliorare, anche se ho lvisto tutti i vostri video.
E molto felice di Enscape, ma alla fine molti di noi aspettano un’alternativa. Con la fusione con Chaos non ci sono stati miglioramenti, a parte il costo dell’abbonamento .
Potresti indicarci comunque come fare foto panoramiche ma non solo roizzontali ma incluso il cielo?
Thank you for your comprehensive feedback. Right away just so you are aware, any specific requests for the future like Enscape providing their own HDR files (which will still be rather unlikely) can be forwarded directly to our product management as detailed here: RE: Switching Public Portal Provider or via the direct link here: https://chaosenscape.ideas.aha.io/
On top of that, please kindly make sure to translate any of your future posts in this forum making use of something like Google translate or such - This way every user can read what you are saying right away (mentioned in our forum guidelines here too). That would be very appreciated and thank you already in advance!
Hopefully I am understanding you correctly here, but we also created a dedicated blog article in regards to taking your own skybox to use as background, with some further additional tips: https://blog.enscape3d.com/custom-skybox-in-enscape/
I hope this helps and feel free to let me know in case you have any additional thoughts or concerns.
Translated:
Grazie per il tuo feedback completo. Tieni subito presente che qualsiasi richiesta specifica per il futuro, ad esempio Enscape che fornisce i propri file HDR (che sarà comunque piuttosto improbabile) può essere inoltrata direttamente al nostro team di gestione del prodotto utilizzando il nostro portale come dettagliato qui: RE: Switching Public Portal Provider oppure tramite il link diretto qui: chaosenscape.ideas.aha.io
Oltre a ciò, assicurati gentilmente di tradurre qualsiasi tuo post futuro in questo forum utilizzando qualcosa come Google Translate o simili - In questo modo ogni utente può leggere immediatamente ciò che stai dicendo (menzionato anche nelle nostre linee guida del forum qui ). Sarebbe molto apprezzato e grazie già in anticipo!
potresti indicarci comunque come fare foto panoramiche ma non solo roizzontali ma anche il cielo?
Spero di aver capito bene qui, ma abbiamo anche creato un articolo sul blog dedicato a come utilizzare il tuo skybox come sfondo, con alcuni ulteriori suggerimenti aggiuntivi: https://blog.enscape3d.com/custom-skybox-in-enscape/
Spero che questo ti sia d’aiuto e non esitare a farmelo sapere nel caso avessi ulteriori pensieri o dubbi.
super late reply but I managed to find an HDRI in an elevated camera view here :
https://3dzip.org/download-free-hdri-from-hoang-tk/
