I have a question. I am trying to map some displacement gold text on a wooden gun handle. The first one I did I really liked the texture fit (spherical) of the wood. Then I put together a layered version with the gold text on top but I don’t like the mapping (flat) of the wood. Is there a way to combine spherical (for the wood) and flat (for the raised gold text) somehow in the layered material? Many Thanks John
I assume I insert it as a “effect-projector” between filter and diffuse (labeled in green). Should I do the same with texture, glossiness and bump (labeled in blue)? As soon as I start doing this C4D is crashing a lot as well. Is this a know bug? Thanks again John.
Sorry to hear it’s crashing for you. We will check it out.
Actually, now that I am thinking of it - did you try simple C4D material stacking? That means putting multiple materials onto a single object? If you play with it a bit, you should be able to achieve the desired effect (a decal on the base texture) easily. And of course, each of the materials can have different mapping, because it has its own separate texture tag…
