adjustment layers not covering contact sheet items
If I open a multilayer EXR, create an adjustment layer, then expand the layers and run the contact sheet, the adjustment layer is separated out as another item in the contact sheet. It does not stay over the render pass that I intend it to stay over. Maybe there is a simple solution for this?
Hi, the contact sheet does not work with adjustment layers. Please use them with the regular layout.
