Hi to everyone.
At first I need to say, that you have done a really good Job with Vray 5.
2 Points I really miss so much, that Im not sure if I will downgrade again.
1. Point and this is for me and massive step back - is that there is no adv. Bit Map where I can make fine adjustment on my texture, like hue, saturation, and so on - like in Vray 3.7. This was really really usefull for me, but I feel it just right now, because its not there anymore - hehehe
2. Point which is not so important but I wondering why I can find it anymore are mesh lights - they where very useful for me.
I just like to know if this points will not come in future or if they are on list to too in future?
or maybe there are new ways how I can solve this problems.
I look forward to your answers
Chris
Hi Chris,
for the fine color adjustments you can now use C4D’s Filter shader.
Support for Filter shader without baking
Thank you to all your answer- they where very helpfull!!!
Hi guys,
Is there another solution for now regarding to the mesh light?
I was using it a lot for indirect lights that go arround curves etc, and i cant really find a good way to replace it.
Maybe one of you can help me out with this problem
Thanks a lot and cheers,
Mike
Yes Michael, I miss it also more every day when I work. I didnt realize how much I used mesh light - heheh
Ok, i manage to fake it somehow.
create a vray material, on diffuse layer go to “self-illumination” tag, load a simple plain white image, enable “self-illumination Affects GI” and “Compensate Camera Exposure”, apply the texture to the object you want to emit light and it should work. The brightness of the “light-source” you can than turn up and down by going into the texture and set the exposure of the image to a higher value.
cheers,
Mike
If you’re going to use it with a shader, I’d suggest taking a look into the Light material:)
I just tried it with the light material, didnt know there is one. But when i apply it on my object i want to emit light, nothing happens.
What do i have to do to let it light? When i change the colour multiplier value nothing happens.
can you maybe explain me how it works?
Hi Chris,
A native C4D Filter shader doesn’t seem to work on my materials. Am I missing something?
