Advancewood OSL 3dsmax
is there any reason why the new Advancewood.osl included in the last update of 3dsmax 2022.3 is not working with VRay GPU, there is no problem with the CPU version.
Is the code not compatible with VRay? If it is the case, what can be done on your side ?
We managed to reproduce the issue using the AdvancedWood.osl map. The issue is reported to our bug-tracker (VMAX-11804).
When there is any progress in fixing it we will post an update.
Thanks for the report!
The issue you have reported is now fixed. The fix will be included in stable nightly builds and the next version of V-Ray. You can find a stable nightly build here.
Awesome, I’ll go to try this later, thanks !
