I am getting an opportunity to create some realistic stills and animations for a rug designer. The plan is to buy some nice 3D rooms (have several picked out already, even some C4D and Corona-ready) and replace the existing rug with my client’s design. Mostly likely not too close, but close enough to see texture.
My main issue is getting a rug sample into a nice looking 3D material. The attached rug materials were created with a rug sample I found online, and I used Photoshop to generate a Displacement and Normal map. Somehow it comes out OK, but not as good as I was hoping. In addition, Photoshop will be dropping those 3D filters soon. This scene is just a simple one I setup using a few Chaos models, but it gets the idea across. I’ve seen Materialize which looks pretty good, just have to Boot into Windows to use it. Tried using the Wine app to get it running on my Mac, but I think it doesn’t like the current Mac OS.
I even tried to extract the 3D depth data from my iPhone photo, but it’s very low-res in the sense that it is good for large items with large distances between. Shooting a rug only gave me a mostly flat grat image with not detail.
So I’m looking for suggestions on how best to create PBR texture set for rugs. Any advice is appreciated.
Boy is Adobe bad at getting the word out. I have the Master Collection of Creative Cloud and had no idea this app(s) were available since last year. Costs extra, but if it works it’s worth it. It did a better job than Photoshop as making the channels using the same sample color image. Just might work. Thanks for the heads-up!
Still looks a little flat, but this is just 5 min. work.
It’s always these sharp edges on rugs that are a dead giveaway. Also make sure your actual texture is a large enough sample to avoid obvious tiling.
I would experiment with a mixture of rug texture and corona hair to get better detail, variation and realism.
That rug in the tutorial came out super nice. In my case, I will be provided with samples of actual rug. Not sure maybe 1’x1’ or 2’x2’. The first round will be solid colors so I just have to get the texture close. From that video, I’m going to add subtle displacement and rounded edges first.
Here’s another example using a carpet material from the Corona library, but also added a noise Displacer Deformer with the Zada noise. Adds a nice randomness, specially to the edges.
So as I mentioned earlier, I tested the depth map from my iPhone X and found it was good at large objects, but not so much small details. Turns out the new phones, 12 and 13 Max, have a actual LiDAR sensor. Two questions: has anyone tried using their new iPhone’s LiDAR tech to create materials? Is anyone willing to send me a sample photo so I can test it by extracting the depth data?
Could you find carpet materials you like in places like Poliigon or Turbosquid to get the right look for bump and displacement and then use a Corona decal to add the pattern/design to the carpet?
That might be a possibility. I just don’t have the samples yet so don’t know how easy that may be. That’s why I was wondering about the LiDAR capabilities of the iPhone.
First off, thanks to all the suggestions on my quest to create rugs. @romullus for Adobe Substance Sample. It does a nice job. I took 8 photos with the light changing 45° each shot. Sampler takes it right in and gets a good base going. Then add some tiling, color equalize, etch and it looks great from sever virtual feet away. I would however, like to up my game and give us more options to get a little closer.
@jojorender That sample you provided is crazy good. I love the idea of the different layers made from separate objects. Simplifies everything. I can’t seem to translate the Max hair settings into anything I can recreate though. I will keep digging around.
Now with Corona v9 out, any possibilities of using Scatter or Pattern to create a rug or carpet look?
I’ve attached a render using the Sampler workflow. At least as good as I’ve gotten so far.
