Aerial perspective sharp horizon line and no alpha
Hi, when i use aerial and i check affect env rays, i have no alpha channel in my objects. How do i solve this?
Also, the vray sky gives me a sharp line at the horizon, how can i remove this?
thanks
Thanks, well i see the sky fine and not sharp. When i add the aerial gets sharp. And the angle doesnt work. Besides that how would i make a pass only for alpha on same scene? thanks
Can I ask what plugin are all the symbols of the left from the coloured ones?
You could make new render without the Aerial Perspective effect and use its Alpha.
Are you asking about PhoenixFD? This is our all-in one solution for fluid dynamics simulations.
You could find more information here:
Hello, i’m a facing a similar issue while using vray aerial perspective. Is there a way that the alpha wont be be modified by this function ? Or could you add an option in future release to ignore alpha ?
Regards,
zero-K
Yes, please add this option :slight_smile:
I’m also facing this issue !! would be really helpfull if this was implemented… Many thanks in advance !
