affect specular/reflection on per material basis for rect light?
Is there an way to set the “affect specular” and “affect reflection” of a rect light on per-material basis for finer optimization/control? Something similar to mental ray’s miaX material’s “No Highlights for Visible Area Lights”? If I enable this in a miaX material, then I won’t see the highlights of area lights in the render.
Thanks!
Hey Jason,
I do not have vray open and I am not sure if this is how you would do it but maybe on your shader you can uncheck “Lock Highlight and Reflection Glossiness” and then set the “Highlight Glossiness” to 0?
Let me know if this works.
Best,
Rich
Hey Rich,
Just gave it a shot and that turned the highlight (the specular reflection of the area light seen on my test sphere) into a big glossy blob…:slight_smile:
- Jason
ah ok. so not that then :frowning:
not sure without looking at vray then but i am not at work today.
sure one of the devs will have an answer.
interested to hear.
best,
rich
Sure thing. Thanks for chiming in, Rich. Hope to hear some feedback from the dev or others.
- Jason
Rich is almost right, just set the highlight to 1.0, not 0.0.
Thanks Vlado. That’s what I am looking for. :slight_smile:
In terms of to be more physically-accurate, should I set this behavior by default (un-check the “Lock Highlight and Reflection Glossiness” and set the Hilight Glossiness to 1.0)? Thinking this because, by default, miaX material enables the “No Highlights For Visible Area Lights”. Or Vray and mental ray have different way to differentiate area light’s specular and reflection contribution to materials?
Nope. The physically accurate value is the default one where the two glossiness values are locked together.
Thinking this because, by default, miaX material enables the “No Highlights For Visible Area Lights”. Or Vray and mental ray have different way to differentiate area light’s specular and reflection contribution to materials?Substantially different, yes. V-Ray needs both the reflection and the highlight for a correct result. It would be best to “forget” what you know from mental ray :slight_smile:
Hey Vlado,
Thank you for the clarification. Really informative and helpful.
- Jason
haha.
thanks vlado.
