found a bug. When I enable lens effects and start render (standard production, active shade, IPR, doesnt matter) vray render two or so passes in progressive rendering, then apply lens effects and rendering go on, but not shown in VFB. I have to change some settings in lens effects and after that lens effects are changes and last pass is appear. Newer pass doesnt appear until I change lens effects settings again.
There’s no bug; the lens effects will be updated again after some more render passes are computed. The lens effects calculations take some time and V-Ray doesn’t do them all the time in order to give more time for actual rendering. By default the interval at which the effects are updated is calculated such that the lens effects take no more than 10% of the total render time.
If we find a way to make the lens effects faster, especially for large resolution images, we can increase this default interval.
I dont get newer image after a lot of passes. I will send recorded video. It includes some things my client doesnt want to show, so I will send it to your mail Vlado.
In video I start IPR, lens effects are applied and then I waiting but image with less noise doesnt appear.
And second problem which I told in different thread is when change frame in timeline. I do it couple of times and it crash. All is recorded in video and both are pretty good reconstructible, so hope it will help.
