After Update9 Chaos Scatter wont install
i have a problem as mentioned in the topic. Tried to uninstall the whole corona renderer, clean files, nothing helps. Everything is fine besides chaos scatter, nowhere to be found.
I need help as fast as possible as i have a projects going on. Thank you
Already figured it out. Installed manually only Scatter as you told in the other topic. Thanks for solution
