Man…Has anyone ever got this message
File Link Error
Unable to open:
V:\directory\annex2.dwg
A serious error occurred. The file may be corrupted or contain invalid data.
I have tried isolating stuff and erasing…blah…blah…I cant figure it out…
Here it is…I wont file link or import into Max 9
http://www.megaupload.com/?d=2LDXYXQN
Thanx for any help you can offer
Re: Ahhhh Help
@EricCamper
When I try to filelink the dwg file in Max I get this message
…so how did you make your autocad file?
…and I can merge it into Max, so if you want the Max file it´s here:
http://www.dalsgaard-design.dk/mis/EricCamper.rar
Preisler
cam you open this file in autocad? maybe save as a acad 2000 file or somthing ?
Eric, I think ‘solid history option’ causes that error. Select all 3d solids and change their solid history to none.
Edit: I get same message with new acad commands such as loft etc.
