How do i select objects in the ai advanced enhancer? - I can see my uploaded image as a base layer but i cant select anything? Help ![]()
Hi @skarn !
If the enhancer detects people, faces, or vegetation, you can select them in the image by hovering directly over it:
Once you’ve enhanced an object, it’ll appear on the right side for editing and add a small blue dot on the object in the image:
It can be picky about detecting faces and bodies. In my example, it doesn’t detect the person on the far right because the dog confuses it, so ensure faces are as visible and identifiable as possible. Vegetation is given a little more leeway in this regard, but make sure it doesn’t blur into something else.
I hope this helps!
Thank you so much! I agree in your answers!
