look @ the images:
rendered directly in ENSCAPE
(clear image with good detailed elements)
rendered with AI in ENSCAPE:
(so weird, deformed, unrealistic …)
Thanks for sharing, this is not what the enhancement should return. May I ask you what are the render settings you have used? I wonder if you could try again with a higher resolution render and let me know if the enhanced image has improved.
thanks @riccardo_cereser
i am using Full HD 1920 X 1080, because when I try to go higher with Ultra HD I am getting this message:
when I try closer, one character appears good, but not the elements in the back
but what I need is the image of the entire project showing good quality…
(without AI it is showing good)
when you go closer in the image everything is deformed…
