AI Factory
Concept work to refine the creation of 3D environments. 3ds Max, VRay GPU, Black Magic Fusion, forest pack, mega scans, RT Textures, 3D Scan Store and Action VFX.
beautiful work!
Yes, nice work!
Thank you both very much!
Like this one!
Is there any environment fog or cloud effect is post?
There is aerial perspective which should be a bit stronger to be honest. The clouds were added in post - I tried creating some mist/smoke in Houdini and bringing it in with VRay volume grid but couldn’t get it looking right. Thanks for your comment!
really good job
nice atmosphere and colors too
Thank you!
Looks great, the atmosphere is quite magical! One thing confuses me a bit: https://dl.dropboxusercontent.com/s/…608_213406.png I believe there should be rocky surface here as well. It looks a bit artiicial imo.
It’s a valid point Oleg. I tried a number of approaches with the rocks and agree they should extend up along the vertical face - a mistake on my behalf. I will check with you next time!!
what is an AI factory?
also you should animate it or at least do some more views. this one is tiny lol
The idea is that it’s a factory for making synthetic humans with artificial intelligence. The secluded location is due to it’s controversial nature. The building is the top of a much larger factory which is mainly underground. The conveyor has been picked out (attached) and the reason for it travelling above ground is to help cure the synthetic humans exterior shell with a mixture of specifically extracted plant chemicals and sunlight.
You’re absolutely right, there should be more images but time was the main factor and it’s part of a much bigger story.
On the engineering side, you would’nt be able to excavate much deep so close to the side of that cliff…:wink: :wink:
Unless the whole cliff is artificial too, obviously!
Super pretty!
If i had to be picky, some of the bushes in the mid- foreground seem to repeat, and distract me a bit.
But those forests and cliffs, man…
nice one and original!
Lele & Jiri, thanks!
