Has anyone tried it?
Looks promising if it works, imagine if/when that tech is in Vray. Denoise and upscale to final res in one.
Edit - tried it out now - and love it!
I think I’ll check it out, too.
I ended up purchasing it. I scaled an image up 600% and it was flawless, just as good as the original.
Yes its pretty surprising. I emailed them, see below some interesting feedback -
* Your license key will work with both the Mac and Windows versions of the software.
* Your license key will work on up to two computers as well (Mac or PC).
* Our developers are working hard on making this software compatible for video. Keep your eyes on our websites and social media for more information on this in the coming months!
Can you imagine once its working on video as well! I’ve run 10+ test using different resolution up scales and on different content, HD frames, VR’s, and all have performed to near unnoticeable changes.
love to see an example if you have time!
I deleted them, but I’ll do another and I’ll post it.
Okay here is the example. I up-scaled it 600%
https://drive.google.com/open?id=1kXYWJSXjE0TP-KXXY9mtW\_9WeIfUJ9T2
great example, thanks! Definitely impressive, love how it both cleans noisy areas and almost adding detail in the wall texture. Be nice to see this extra step added into the vray denoiser!
We usually render at 8k+ the longest side of an interior or exterior image.Now I can render at 4k+ easily and scale later. When you have a good but not so low res. image to scale up, the results are incredible.
My render times are close to 3 to 4 times less now.So far using Brute force was not possible due to render time increase and timeframe to deliver a job. Now I can increase the quality if needed.
It is really like having tripled my processing power.
There are two major things to improve, at least for us.
A batch processing is a must have.Like select a folder at once.We can render videos at HD and scale to fullHD or from fullHD to 4k without problem.
The other one is the alpha channel .The channel is there but my sky in the background is gone. So we have to render a tiff without channel and use the alpha from the vfb to separate the background instead.
Not really an issue.
Fernando Blanco
I wonder how stable this is if you were to run it over an animation?
Unless the original has something happening there. I’ll have to look.
I just did a couple 2K images and sampled up to 4K and it looks perfect! That’s a 4X speed increase.
You can drag and drop a bunch of images, so it does batch, but it isn’t very fast. I only tried the GPU, assuming it is the fastest; I’ll try GPU later. This is a huge deal.
I wonder how well it does with motion blur / shallow focus?
Its producing artifacts. Take a look at the crops I posted.
As long as you only use the 200% it seems near perfect. Indeed the the devs state that its a near perfect upscale. going all the way to 600%, it will have to make up so much detail, it will look wrong in areas. There will always be the odd random issue, but as the AI gets more images to compare it will get even better. It seems a no brainer honestly. And they are working on animations/video as I mentioned before. And for batch, just drop all the files in, no difference to adding a folder really.
It looks like your original image is already sharpened quite a bit, which results in really exaggarated halos in the upscaled image. I guess upscaling before sharpening would give a better result.
