Hi guys,
I was excited to give the AI Material Generator a try, but everytime I click the generate button I get this message: “The material generation has timed out”
- It happens with the samples and with other textures as well
- Using the default settings or customizing them don’t make a difference in this problem
- Clean the computer cache didn’t solve it either
Any recommendations?
try to whitelist the following domains in your firewall:
vray.cloud
cloud.chaos.com
cloud.chaosgroup.com
It still doesn’t work.
I also deactived temporarily the firewall, but it didn’t solve it either.
Can you please send me in a Private Message your cb.log file, located in C:\Program files\Common files\Chaos\Cosmos?
Do you have a firewall? Try white-listing those domains:
You had suggested that in the previous comment.
I followed your suggestion, but it didn’t work.
Does this happen with any texture that you use? Can you please try for example with this one:
Yes, it happens with the samples or with any other textures I try to upload. I tried again with your texture and it still doesn’t work.
