All elements have teh same material but if you can see on pic (albedo render element) show that on the top of mesh albedo is to high
The same problem eith glass object!
This is because the fresnel reflections make objects more reflective at grazing angles. This is totally normal and not a problem. A problem is when the majority of your scene has superbright diffuse/reflective materials that show red in the albedo element.
Thank You!
