aliased hotspots from vray lights?
I’ve noticed if a VRay light is visible in the camera, or if a light hits something too hot, a kind of glitch appears even if clamp colors is on. For example the highlights in the car’s headlights in this image:
http://www.trinity3d.com/ebay/corvette\_test01.jpg
(high res - 500kb)
This was lit with VRay Sun and I saw the other thread about white dots, but I was wondering about the aliasing also. When I used a VRay dome light and let it be visible in the scene, it seems to wig out vray in the scene.
thanks for any tips on this -
Jim
Have you got sub-pixel mapping checked as well?
Dan
I will check that and re-render, thanks for the note. The manual doesn’t really mention this issue in the section on Sub-pixel mapping, but reading around the forum it seems that is the main thing it takes care of.
If you hadn’t got it checked then I think that will cure the black line around the highlights. There is something about this in the manual somewhere under migration to 1.5 I think.
Dan
another problem could be your imagefiltering. If you´re using any of the filters that have negative values in their filtercurve (sharpening filters like catmull rom) then the extremly bright spots caused by a sun highlight will cause trouble. Try switching to Area to test.
Regards,
Thorsten
