Is it that hard to implement regionRender on Vfb ? (this is not an ironical question, i am curious). I use it a LOT and it´s a pain in the ass to use Max VFB just for setting it…
About the render region control in viewport, it is of course usable yet imho its still way easier to control it inside the vfb - matching pass count, selecting those parts which needs some re render due to a different hd cache after prevous region render etc. not to say viewport region controls are completely useless when it comes to spherical/panorama renders …
I will ask the exact same thing Keymaster! Color mapping in Vray is always an issue for me.. so haveing this one would be much better!
And also, very important, gloom and glare in the vfb in realtime like in maxwell ( and Fryrender, it was awesome, was working perfectly and so realistic! now it’s Arion but I don’t know I did not tryed it so.. ) so you can load map and adjust parameter while it’s rendering and you see the effect taking place.. really a must Corona gonna be a one of a kind with all these cool features
What about to add Highlight compression, white balance and contrast (in relevance order) in CameraMod? Changing exposure often need highlight compression adjustment, and so on for the rest.
Btw, testing last daily build (2014-10-14) I found that if you use photographic exposure, exposure value in vfb has no effect (correct), but ISO value has effect and does not change iso value in cameraMod modifier (uncorrect)
Congrats and hats of to the corona development team! You have a very easy to use Render engine which lets artists be artists.
I did not want to open a new thread to request a DIRT MAP feature and a Vray style Blend Material. The standard Corona material is great but it does not allow for the creation of a more complex and therefore realistic Shaders. I am working on a scene right now and I need a detailed layered metal shaders with multiple scratch, specular rust and dirt layers but there is no way I can achieve this with the standard Corona Material.
in the mean time is there anyway to convert veray blend shaders to a corona shader, I am guessing not since the equivalent shader does not exist in corona.
Actually i installed VFB+ demo couple weeks ago, but i didn’t like it as much as i expected. Thing is, if i want to use it with Corona, i loose all the goodies Corona’s VFB has and i don’t like it. Now, if there’d be a way to marry those two, that’ll be an ultimate tool.
I’ve created a script for corona in mind which toggles the area to render (region render) without the need to open up the render dialog etc. It has pass limit, resume render etc. If you would like any features added please let me know.
Well, I’m rendering with corona and when finished open VFB+
That’s my poor way to have both world
But I already had strange effect with VFB+, like saving all passes in a click, and ending with beauty of my current render but passes from previous render -_-
Very useless for post.
This said fireflies suppressor, sharpener or bloom, aren’t much of rocket science and are pretty handy straight from VFB.
Now I wonder who is gonna make a lenscare alike yumi yumi
I would hardly reproduce it as the demo is over since a while (and I missed your post for awhile sorry about that), basically I tried to save all pass in a EXR (or psd?) and the if beauty was correct (the thumb too), other passes (materialID, Zdepth,etc) were from previous render (in history). I was pretty surprised as looking at the thumb it seemed correct and I closed 3dsmax to launch photoshop… before being somewhat disapointed (was testing purpose anyway nothing prod related)
Your bloom is super nice, although sliders are very very very sensitive in general !
That autodesk didn’t bought your vfb is somehow proving that it’s a good one
Render Mask for Reflective and Refractive objects…
I know there is an option to turn off/on visibilty in mask for Objects - but since then there is no option yet (correct me if i’m wrong) to get an mask from those objects without rendering a second pass with “visibility turned on”.
Either i wish a render mask options like V-rays affect channels “all channel” for masking options
or at least have an option in Cmasking_Mask to select objects who override the “visibility turned off” choice in material.
So i’m at least able to render out all masks including those of refracting materials within one render-session.
