I’ve working in it while weeks but seems without luck… this is only an example:
That its my original model with GI
This is the same model with the GI too and the baked lightmap putted on
As you can see ,some edges are wrong because the texture don’t fit at all with the uvw map.
All of you the text. and uvw map works correct? If yes , how you get it?
All help will be apreciated
Thanks but I only put it in diffuse map to show the fail better.
If I put it into the light channel I see the teapot in yelow colour, but the lightmap don’t fit at all.
If you take the PNG created from Bake3D into Photoshop you’ll see that there is an Alpha, which is causing this problem. I’ve always just tweaked the texture in PS and in some cases I export as a different file type altogether.
