All white Enscape renderings
Hi! I am new to Revit and am trying to model in Revit but when I go to Enscape to render my 3D views, all of the materials I’ve applied are white. Is there something I need to change in the view settings to fix this? I’ll attach images of what I mean below. Also, I am using the newest software Revit 2024 and Enscape 3.5.
Mine is doing the exact same thing. My paint comes in, but most everything else is white.
This worked:
When making material, in asset library, start with (Appearance Library) Default-Generic. Then apply an image in the Appearance tab.
Not sure why the out of the box materials are not working. Have had this issue before.
Hope that helps! Let me know if you find a simpler solution.
