Allow change proxy's transforms on the same level as mesh objects
Currently, it’s only possible to change proxy’s transformations with transform gizmos, but neither xform, nor linked xform modifiers does not affect its transformations. That leaves no options to change proxys transforms when used in cScatter. It’s either xform/linked xform should affect proxy’s transforms, or proxy should have its own transformation rollout in modify pannel.
This request originates from that topic: https://forum.corona-renderer.com/ Corona scatter SCALE ROTATE distributed objects ??
Already logged.
(internal: id=309734046)
This is one of the features of Chaos Scatter and you will be able to try it in the upcoming daily build.
More info on Chaos Scatter and Corona 8 in general: Renderer for architectural visualization - Corona | Chaos
