ALLUSERS parameter not working
Hi there,
I’m trying to deploy Enscape for Revit to several users.
I have the following command line being used and you’d expect it to install for ‘allusers’ and not restart, but it doesn’t.
msiexec.exe /i Enscape.msi ALLUSERS=“1” /norestart
The installer shows the following and have ‘Install just for you’ ticked as default.
Any ideas?
Thank you.
@bumologist , in this case simply make sure to actually NOT click advanced and just continue the installation.
You should be able to see the following indicator (which is the little Administrator “shield” icon") next to the install button:
This means it’ll be actually installed for all users.
