I always render to EXR (16 bit) with the different CESSENTIAL passes included. Just the way I did in A6.
With A7 I think that colormapping, especially Highlight Compression, is not saved within the CESSENTIAL passes.
It is only saved in the beauty pass.
I hope it’s a feature
It doesn’t make sense to save out render elements with color mapping because you can’t recombine them to get the beauty. So it’s absolutely necessary to save them out linear without any highlight compression, combine them, and add highlight compression later.
OK, but I guess at this moment EV en contrast are saved in the passes. And if I understand you will they shouldn’t be saved???
Anyway for the moment I will try to fix it in After effects.
EV shouldn’t be a problem since it’s only multiplying everything by x (linear), but contrast shouldn’t be saved then, that’s right.
You can simply do the same highlight compression as in corona by using this formula for each channel like this:
n1 is the amount of compression
r1, g1, b1 is the (float) value of the pixel in r, g or b
r1 * (1+r1/(n1*n1))/(1+r1)
g1 * (1+g1/(n1*n1))/(1+g1)
b1 * (1+b1/(n1*n1))/(1+b1)
there was a bug, which is fixed now, and render elements are now saved WITH colormapping (sans gamma). The user is responsible for ensuring he uses correct workflow. Unfortunately this cannot be done better since 3ds max is more or less tone mapping-oblivious and does not permit displaying and saving images with different color mapping
