Alpha + Bloom and Glare
I’m trying to render an animation as an image sequence with Alpha channel. How do I get the bloom and glare to come through on the alpha pass? It just cuts the bloom and glare off at the moment. Should I be using multi-pass?
This is a known issue and the developers are aware of the problem. Sounds like a fix is coming some time in Beta 2.
Ah, I see.
