If my cheap laptop lcd isn’t lying, there’s a slight grey gradient on the side windows. It might be a bug. Or maybe your windows aren’t 100% transparent?
maybe i wrong, but i think refractive area must be white color
P.S. render PT+PT, illumination - standart (corona sun +corona sky), corona alpha 3(not daily build)
glass materials’ alpha is not pure black, because those have also reflection
when environment is visible through glass, the alpha should come out black, as it is on the columns in your example. Unless you change alpha mode to solid.
