Alpha channel render element
Does Enscape render one? I only set a matid and zdepth pass.
that Z pass can be made like aplha too , just increase distance and u will see …ofc its not perfect but i am able to choose openings or windows by this method corectly …
litle example …
that black is a pure refraction of the windows glass .
Not yet, but this subject is filed as a dedicated feature request on our agenda - I’ll add your upvote to it! :slight_smile: What would be your use case for that?
Excuse me,can i ask What usually Depth is used for in post processing? I know the material-ID is for selection.
well if u want "alpha channel " then set dof lenght to the max and u will have only BW image …
@jan1 oh, i see, it is for mask in PS. Thanks a lot!
or u can use regullar depth map for fog of volumetric effect , but enscape got that from default …
