Alpha Channel with Foliage not working good
Good morning community,
yesterday I noticed once more that in all of my scenes where I have a transparent background which I wanna replace in photoshop/affinity. I always have an alpha channel which doesn´t seem to be correct. Especially not in areas where I have foliage. I already searched the web for solutions and asked on a 3ds max discord but nothing really worked for me. To better show you what I´m talking about I have a few images here as an example:
I`m mostly using VRay Dome Lights with HDRI but if I recall it happened when using VRay Sun and Sky, too. I´m always rendering 32-Bit .exr-files cause our prof at university wants us to. Is there any elegant way to fix this? It´d be really important for me cause I feel that most of my renderings suffer from that.
I used VRay 5 for the last months and downloaded the Update 1 once it came out.
Thanks a lot in advance!
You will need to render against a black background - just make your dome invisible. That’ll fix it :slight_smile:
Thanks a lot for your reply! I tried that out in the last 1-2 hours but I noticed that the results look a bit different. I just rendered a small part of the whole image to save some time. As it seems it´s the refractive materials that look completely different. Is there any fix for that? Except for those materials, it seems to work at first glance. I´d need to render the whole image so that I have a better comparison.
Check that your glass/water etc shader has enough reflection/refraction depth and that it is set to colour/alpha…should fix it…
As it seems that didn´t help :(. I doublechecked both materials, wine and glass. I set the materials to colour/alpha and increased the max depth to 30, 50 and even 100 to try it out but that didn´t change anything. Then I tried some materials from the V-Ray material library. Wine, standard water and orange juice but they all looked bad as well with the Dome light set to invisible. Once I make the Dome light visible again, all those refractive materials look a lot better.
Edit: It seems to work with the swimming pool water though. Once I make the Dome invisible the water still looks the same.
Hmm…did you check ‘max transparency levels’? Possibly that is either too low or you have the override on…hard to say as I can’t replicate it in my simpler test.
Feel free to dropbox a cut down scene and I can see if I spot anything odd.
Add the HDRI to the reflection/refraction override in VRay Environment
Oops…forgot about that one. Problem solved.
The trick with the reflection/refraction override in VRay Environment seems to work! In IPR it looks good already! I´ll let you know tomorrow once my rendering is finished and when I could try out the composition in Photoshop!
Thanks a lot already, you two!!
Edit: Just finished rendering. Everything works perfectly in Photoshop and Affinity!! Thanks a lot again for your help!
