alpha inclusion from Post effects
It would have been great if post effects would work with images rendered with transparency/alpha. Currently there’s no point using the post effects that bleeds outside the object if you need the transparency, since the outer post fx parts will be cut away.
Which specific “post effects” do you mean? Bloom and glare?
Yes, bloom and glare, sorry for not being specific. Mostly bloom though, since that’s the one that always bleed outside the models boundaries.
