Alpha problem with backplate
I’m on Mac with Corona 6 hot fix 1 and C4D s22.
I have a simple scene with a backplate for the sky (not for lightning the scene but only for visibility). This backplate is assigned with a light material where I put the picture of the sky. This material emits no light (Emit light to OFF) and in the advanced settings I have unchecked the Visible to alpha channel…
Now when I render the images, the backplate is still visible in my alpha !!! why is that ?
Thanks for your help.
Best
stefan
Hi Stefan,
Can you share your scene with us via our private uploader?
I have just uploaded the files
Hi Malindis,
Is this what you were trying to do?
yes, what am I doing wrong :confused:
For your clay material, I enabled “Always black” in the alpha mode.
OK but what do I do when I have multiple material assigned to my scene :confused:
It should be working by default so it looks like there might be a bug with a light material on a plane when working with the alpha channel. Instead of the background plane, you could replace that with a Corona sky and set the projection to frontal. With a few tweaks, you should get an identical look as to that of the background plane.
