Alpha v4
Just released! 3D Rendering Blog for ArchDesign, ArchViz, Media & Entertainment | Chaos
Make new scene. Make Cub. Make material. Assign Material to object. Right click to material. Press Render Material - OBJECT disappears!))
Thank guys, great work! Is it possible to implement custom threads priority to interactive rendering in future? It would be more nimble for working and interactive rendering at the same time.
I think I know where is problem. Can you confirm object reappears once you do any modification of corresponding material (e. g. change color or double click material preview)?
Is there a way you could make a check box “Do not override” in the material properties? This way if someone is using sky object + material with HDR applied it wouldn’t get overwritten.
changing the colour makes the object come back, or checking the reflect box, etc.
I’ve found the interactive render quite prone to crashing C4D. Would you recommend starting older scenes again from scratch with A4?
Does “material override” work at all? I’m trying to figure out why I’m getting a black render.
seems to work fine here, although not in the interactive render window
Congratulations guys this is a fantastic release so far everything I have tested texture related has been working perfectly. I will certainly report any findings. Thanks again for all your hard work! - Shawn
Oh I’ve missed a exclude/include input below the “override material” check box. This solves the issue with skye + HDRI.
And it’s working fine now!
Thanks guys, great job!
cheers
m
Yes. I confirm it. If a do any modification - object reappears.
Yes! Ales! Any modification of corresponding material ENABLE back object in viewport
Thanks I will check it now!
What’s with the bump channel? I must now set values above 1000%, where 10% were still needed in the A3. I am surprised that has not been written about. Or is that just me?
Otherwise, I’d say thanks for your great work :o)
This was already reported in the beta testing, but not fixed yet
WRONG Preview “Open window” with glossy map texture, diffuse texture
need fixit
Light material doesn’t work in A4 with C4D sky. I tried to use portal with it.
Standard material with HDR in emission chanel, whith corona portal work good.
interactive rendering is very slow,much slower than 3dsmax, and makes the software crash¨.
also material converter does not work… or its just me !!?
Poor working bump, we have to set the value in 2000 - 3000%, for the appearance of relief. Channel reflection, as has begun to lose. Interactive rendering slow and bad displays a map hdri
